Netbotz 750 no web access
  • EcoStruxure IT forum
  • Netbotz 750 no web access
124
65
Back to EcoStruxure IT forum
Mike-Sutton
Lieutenant Mike-Sutton
Lieutenant
Posted: ‎2020-08-26 06:48 AM
7951
I have upgraded a 750 to 5.2.2 however i now cannot access it through web browser to enable SNMP to add it to DCE keep getting error 503. I have tried all ways to reset to default settings but unable see response ls comand shows ddf.zip ?? i am currently on site and this is my last task. any solutions would be helpfull as cant leave till added......
TIA
Mike
  • NetBotz
Captain
Posted: ‎2020-08-26 06:57 AM
4
7939
Hi @Mike-Sutton ,
This error is usually due to the device having an old (original?) version of firmware and not being reset to defaults after upgrade. From the version you currently have onward, this should not be necessary but the I suggest resetting to defaults and reconfiguring it :
http://www.apc.com/us/en/faqs/FA370681
Steve
Replies 6
Captain
4
7940
Hi @Mike-Sutton ,
Steve
Officecitygn
Ensign Officecitygn
Ensign
Posted: ‎2022-09-07 01:34 PM
In response to APC_Steve
In january, the tech person of Apc in West africa perform a firmware update in our Data center Netbotz. Since this time the Netbotz "bug" error 503 occur so he follow your procedure....but it happens again and again...every 20 days there is a Netbotz loss. The customer is very upset with Schneider and it will have a huge consequence and the west african support is totaly lost...not able to solve a problem they create after firmware update.
reej
Ensign reej
Ensign
Posted: ‎2022-09-19 08:14 AM
6381
Update to the latest firmware and remove with HTTP WEB access the (WEB->SSL) certificate and reboot the network card,
If HTTP is disabled then enable it first on the CLI with Telnet.
command: web -h enable
https://iportal2.schneider-electric.com/Contents/docs/UPS-PMAR-9LLM9N_R1_EN.PDF
https://www.apc.com/au/en/faqs/FAQ000233142/
  • SSL issue
Officecitygn
Ensign Officecitygn
Ensign
Posted: ‎2022-09-19 10:02 AM
In response to reej
6364
The problem is the Netbotz 750. Not the ups. We access the ups without problem.
reej
Ensign reej
Ensign
Posted: ‎2022-09-19 11:41 PM
In response to Officecitygn
I understand, but i thought i has has same network management card structure, maybe it also affect the Netbotz 750.
Thanks for feedback!
Ericksson_Cardoso
Ericksson_Cardoso
Cadet
Posted: ‎2024-03-26 08:58 AM
I own a netbotz 750 after an update I cannot connect to it , still no support from Schneider
