Ask Me About Webinar: Data Center Assets - Modeling, Cooling, and CFD Simulation Join our 30-minute expert session on July 10, 2025 (9:00 AM & 5:00 PM CET), to explore Digital Twins, cooling simulations, and IT infrastructure modeling. Learn how to boost resiliency and plan power capacity effectively.Register now to secure your spot!
Netbotz 750 Dead on Arrival
Send InviteCancel
Posted: 2025-08-2901:10 AM
Has anyone had a Netbotz 750 new out of the box not boot
I thought perhaps there is a manual way to select voltage but it simply wont proceed, ran the boot command but cycles back to the same error.
U-Boot SPL 2018.04 (Aug 30 2019 - 14:54:28 -0400) Trying to boot from SPI
U-Boot 2018.04 (Aug 30 2019 - 14:54:28 -0400)
CPU: Altera SoCFPGA Platform FPGA: Altera Cyclone V, SE/A6 or SX/C6 or ST/D6, version 0x0 BOOT: QSPI Flash (3.0V) Watchdog enabled I2C: ready DRAM: 2 GiB MMC: dwmmc0@ff704000: 0 Loading Environment from SPI Flash... SF: Detected s25fl512s_256k with page size 512 Bytes, erase size 256 KiB, total 64 MiB OK In: serial Out: serial Err: serial Model: ECP SNARC SOCA9 2G for Bestla board Net: No ethernet found. Hit any key to stop autoboot: 0 Card did not respond to voltage select! Card did not respond to voltage select! ERROR : the map table is corrupted.........0x4c450880 mapTable : crc=4086c448 ERROR MAGIC NUMBER: probably because there is no map table. ecpmt_banks_load - Set enviroment variable for ECP_FWU banks
Usage: ecpmt_banks_load ## Error: "check_rtc" not defined Card did not respond to voltage select! ** Bad device mmc 0 ** Card did not respond to voltage select! ** Bad device mmc 0 ** SF: Detected s25fl512s_256k with page size 512 Bytes, erase size 256 KiB, total 64 MiB device 0 offset 0x140000, size 0x800000 SF: 8388608 bytes @ 0x140000 Read: OK Detected SoCA9 Snarc board revision=4 FPGA updated to correct revision. Minimum FPGA Release: 7 FPGA Git Commit ID: 0x6a72ce7c, Build unix timestamp: 1525264765 Card did not respond to voltage select! Card did not respond to voltage select! ** Bad device mmc 0 ** Card did not respond to voltage select! ** Bad device mmc 0 ** SNARC_SOCA9_BESTLA_2G #
There may be a command or two that tech support can try with you so I suggest that you contact your local support directly. If that fails, you'd already be in contact with them for a replacement should that be necessary.
