Netbotz 570 & 750: Compatibility with IP Cameras with PTZ
  • EcoStruxure IT forum
  • Netbotz 570 & 750: Compatibility with IP Cameras with PTZ
126
65
Back to EcoStruxure IT forum
SESA380953
SESA380953 Schneider Alumni (Retired)
Posted: ‎2020-06-11 08:15 AM
1558
Hi All: Could you give us a hand to clarify if there are compatibility of Netbotz 570 & 750, with IP Cameras with PTZ?:
  1. Which vendors would apply?
  2. If answer is yes, would it need additional power source?
Thank you in advance.
  • DCIM Support
  • IT Expert
  • NetBotz
  • Tips and ideas
Captain
Posted: ‎2020-06-11 08:29 AM
The version 3 NetBotz appliances such as the 450 or 570 support a limited number of Pelco cameras. These are listed in our knowledge base and this document as well as release notes for newer NetBotz firmware are updated when and if new cameras are tested:
http://www.apc.com/us/en/faqs/FA158450
Some of the Pelco cameras are PTZ.
No other cameras are supported on these version 3 appliances.
I am aware most of these are older and out of date however no new cameras are being tested at this time.
For the NetBotz 750, no PTZ option is enabled on the appliance. We officially support the NBPD0165 IP camera which does not use PTZ.
No other cameras have been officially tested but the 750 should be able to connect to any camera that uses the ONVIF 'S' standard.
Please also note that the ONVIF 'S' standard does not support motion detection and if you require motion detection on the 750, the NBPD0165 is the only option at this time.
Steve
Captain
Steve
