Netbotz 450 not loading all boot processes
  • Netbotz 450 not loading all boot processes
129
72
Posted: ‎2020-07-05 12:16 AM . Last Modified: ‎2024-04-04 12:57 AM
1327
Hello All, I have recently encountered a puzzling issue with a Netbotz 450. Connecting to it serially via terminal. The appliance hangs while booting up, see below:
The appliance hangs at Net: FCC1 ETHERNET
Note: appliance is operating with the latest firmware, date of manufacture: 2018/03/09.
Nothing loads after that. What might be causing this issue?
U-Boot 1.1.4 (Oct 31 2017 - 14:32:43)
MPC8248 Reset Status: External Soft, External Hard
MPC8248 Clock Configuration
- Bus-to-Core Mult 3x, VCO Div 4, 60x Bus Freq 16-50 , Core Freq 50-150
- dfbrg 0, corecnf 0x10, busdf 3, cpmdf 1, plldf 0, pllmf 3
- vco_out 400000000, scc_clk 100000000, brg_clk 100000000
- cpu_clk 300000000, cpm_clk 200000000, bus_clk 100000000
- pci_clk 33333333
CPU: MPC8248 (HiP7 Rev 14, Mask 1.0 1K50M) at 300 MHz
Watchdog enabled
I2C: ready
DRAM: 128 MB
FLASH: 64 MB
PCI Scan: Found Bus 0, Device 22, Function 0
PCI Scan: Found Bus 0, Device 22, Function 1
PCI Scan: Found Bus 0, Device 22, Function 2
In: serial
Out: serial
Err: serial
Net: FCC1 ETHERNET
(CID:134038009)
  • NetBotz
  • bug
Posted: ‎2020-07-05 12:17 AM . Last Modified: ‎2024-04-04 12:57 AM
1327
Hi Thabos,
I've seen a few instances where the reset button has been stuck "in" and it can cause the boot to hang or the system to constantly reboot. My first suggestion is to get a paper clip and push in on the reset button and move it around a little to see if that resolves the issue.
Other than that, it might be a firmware issue. I'm not sure where these lines are in the boot process but if it gets past the u-boot load (where it says press any key within 10, 9, 8....) then I would suggest reflashing the firmware using the tftp flash procedure here:
Steve.
(CID:134038137)
1328
Hi Thabos,
Steve.
(CID:134038137)
Hi Steve
Thanks for the response, I'll check if the reset button is stuck. i have a feeling that might be the cause. 😀
as for where it says press any key within 10, 9, 8....). the boot procedure doesn't reach that point.
(CID:134038431)
Posted: ‎2020-07-05 12:17 AM . Last Modified: ‎2023-10-22 03:19 AM
