Netbotz 250 - Qty and compatibility
  • Netbotz 250 - Qty and compatibility
128
Posted: ‎2020-07-03 01:37 PM . Last Modified: ‎2024-04-08 01:34 AM
899
Hi there,
Is it possible to mix wireless and wired sensors? How many of each one together? To use the maximum of sensors, is it necessary a power supply (AP9505i)?
To use three or more handles, is it possible to use a NBRK0250 just as a "sensor pod" for handles?
Thanks, masters!
(CID:113642846)
  • NetBotz
Hi Anders,
If you need more than 2 handles, you will either need to get a second 250 or you'll need to go with something like the 570 with rack access pods NBPD0171.
You can mix wired and wireless.
The quick config guide is here:
http://www.apc.com/salestools/JLER-A4CL7S/JLER-A4CL7S_R0_EN.pdf
It notes up to 47 wireless sensors
Up to 8 A-link sensors AP9520T/TH
Maximum number of NBPD0150 sensor pods is 6...each capable of connecting 6 wired sensors in addition to the ports available on the unit itself.
The 95051 is recommended in larger configurations. I believe it is stated that one for every 4 pods but depending on where you have it installed (interference) and how far away the pods are, you may need to use more.
Steve
(CID:113642903)
Hi Anders,
Steve
(CID:113642903)
Posted: ‎2020-07-03 01:37 PM . Last Modified: ‎2023-10-22 03:16 AM
