Netbotz 250 Door sensors
  • Netbotz 250 Door sensors
129
72
Posted: ‎2020-07-05 05:31 PM . Last Modified: ‎2024-04-03 03:20 AM
1107
Does anyone know how to create an alert for when a door sensor is open that it triggers the relay output?
From my research it appears this should be possible from the Netbotz Advanced view software but i cant get it to add the Netbotz 250 it just keeps kicking me to the login page.
(CID:140708754)
  • NetBotz
E W,
The NetBotz 250 does not utilize the advanced view software.  I do not believe that the rack access door switch sensors can be utilized to control anything within the NetBotz Appliance that is not directly related to rack access.
In order to have a door sensor trigger a relay output, the door sensor would need to be connected to one of the 6 universal sensor ports or a sensor port on a sensor POD 150.
Within the 250's web interface, navigate to: Configuration > Device > Outputs > Relay Output.  Here can you configure "Input State Sensors" for "Abnormal State".
Kind Regards,
Cory
(CID:140708785)
Dear E W,
Tell us, please, did you solve your question or not?
With respect.
(CID:141269246)
Posted: ‎2020-07-05 05:31 PM . Last Modified: ‎2023-10-22 03:16 AM
