Posted: 2020-07-03 04:14 AM . Last Modified: 2024-04-08 11:43 PM
I am facing a problem in NetBotz 570, in advance view there is one Remove Sensor option which is hide now, before it was was working. kindly help me how can I remove the sensors . see the attached Screenshot.
Ali
(CID:106209909)
Ali,
The only time that you can remove a sensor is when it is no longer plugged into the appliance. It will show in the sensor pane (bottom left hand corner of advanced view) as unplugged. The sensor is in a status of N/A, not unplugged, which is why you can't remove it.
How many sensors are plugged into the that specific sensor pod?
Cory
(CID:106209915)
Posted: 2020-07-03 04:14 AM . Last Modified: 2023-10-31 11:25 PM
