NetBotz250 and spot fluid sensors limitation
  • NetBotz250 and spot fluid sensors limitation
127
65
Posted: ‎2020-07-03 10:10 PM . Last Modified: ‎2024-04-07 11:10 PM
1028
Hi Team!
I cant find any info about maximum number of NBES0301 sensors can be connected to 250's appliance. Is it still 2 per pod or all 42 sensors can be spot fluid sensor?
(CID:123998736)
  • NetBotz
Replies 9
Posted: ‎2020-07-03 10:11 PM . Last Modified: ‎2024-04-07 11:10 PM
1028
Hi Valentin,
The limit of 2 spot leak sensors per pod is hard coded in the NetBotz 3xx, 4xx, and 5xx firmware. The NetBotz 250 has totally different firmware and has no such limitation.
Steve
(CID:123998740)
Thanks you Steve!
(CID:123998790)
1028
Dear Valentin,
As per Netbotz Product compatibility Matrix, it looks like NBRK0250 support max. up to 2 Spot Fluid Sensor.
Steven Marchetti-Is this compatibility matrix need to be updated?
Bala
(CID:123998766)
Thank you Bala!
(CID:123998791)
Hi Bala,
I know it is not a hard coded limit on the 250. I'm double checking to verify this recommendation.
Steve
(CID:123998797)
Just FYI,
I've a message in with product management to see if we can get the matrix changed.
I've spoken to engineering who stated there is no known physical reason for not being able to connect six spot leaks per pod.
Steve
(CID:123998868)
I spoke with product management and they're planning to take that note out of the compatibility matrix with respect to the 250.
(CID:123998952)
Thanks Steve!!
(CID:124520168)
Posted: ‎2020-07-03 10:11 PM . Last Modified: ‎2023-10-22 03:15 AM
