Posted: 2020-07-05 07:17 PM . Last Modified: 2024-04-03 02:42 AM
Attempting to update NBWS100H/T sensors and NBWC100U using the Wireless Device Firmware Update Utility 1.0.1.03. Is there a wireless_firmware.zip file that has the 1.1.1 and 1.1.2 zigbee files.
(CID:143757837)
Hi Barry,
If the wireless sensors are connected to a Netbotz v3 appliance you can follow the set of instructions below:
Access the http://
Once all sensors that have pending firmware is now the same as the latest firmware push the Apply firmware update button in the UI or select the "apply firmware update" option from the drop-down on the web menu of your appliance (http://
After clicking the submit button, you should expect the following:
Justine
(CID:143759205)
Hi Barry,
Access the http://
Justine
(CID:143759205)
Hi Justine, have been using the update utility to verify and upgrade sensors before sending them to our remote locations. Using the utility is much quicker then using the NetBotz appliance. On average the utility will update a sensor within a couple of minutes where as the NetBotz appliance can take up to 48 to 72 hours. The latest utility upgrade 1.0.1.03 provided the wireless_firmware.zip file which had the 1.0.4 and 1.0.6 zigbee files.
(CID:143759415)
Posted: 2020-07-05 07:17 PM . Last Modified: 2023-10-22 03:14 AM
