NetBotz Smoke Detector SNMP OID
  • NetBotz Smoke Detector SNMP OID
129
72
RichardParry_apc
Crewman RichardParry_apc
Crewman
Posted: ‎2022-08-26 02:59 AM
1
1146
Hi All,
I have a NetBotz setup I've just added 2x smoke detectors to. One is off the NetBotz 250, and the other is off a NetBotz 150 Sensor Pod.
As there's no documentation of SNMP OIDs I've always use Paessler SNMP Tester to obtain the OIDs for sensors on NetBotz, very handy. It's easy when working with a temperature sensor, as you can easily find that in an SNMP Walk, but I dont know what states are reported for smoke detectors.
Does anyone know what the "No Smoke" SNMP output value should be?
I've ordered a "smoke detector spray tester", so I can hopefully trigger both sensors into a smoke state, and see if I can compare the results in the SNMP Walk. That's a bit of a faff, but any other ideas?
  • NetBotz
Admiral
Posted: ‎2024-05-05 08:02 PM
Hi @RichardParry_apc,
  • Smoke sensors can be found in the following section of the MIB:
    .iso.org.dod.internet.private.enterprises.apc.products.hardware.environmentalMonitor.envMgtSystem.emsInputStateSensorStatus.emsSmokeSensorStatusTable
  • .1.3.6.1.4.1.318.1.1.10.3.20.2
The sensor status OID would fall under:
  • .iso.org.dod.internet.private.enterprises.apc.products.hardware.environmentalMonitor.envMgtSystem.emsInputStateSensorStatus.emsSmokeSensorStatusTable.emsSmokeSensorStatusEntry.emsSmokeSensorStatusSensorState
  • .1.3.6.1.4.1.318.1.1.10.3.20.2.1.4
The possible states of the smoke sensor:
  • smokeDetected (1) indicates there is smoke.
  • noSmoke (2) indicates there is no smoke.
  • unknown (3) indicates the state is unknown.
Cory
