NetBotz 250 minimum voltage threshold violation
  • NetBotz 250 minimum voltage threshold violation
126
65
GaborNovak
Lieutenant JG GaborNovak
Lieutenant JG
Posted: ‎2022-07-25 03:43 AM
1056
NetBotz 250 keeps dropping the following errors. This NetBotz 250 is used to monitor the genset dry contacts. The environment temperature is not above 45 degrees. Just one sensor sends this kind of errors.
Input sate sensor connected dissconnected 1.pngInput sate sensor connected dissconnected 2.png
What can be the problem?
  • NetBotz
Admiral
Posted: ‎2024-05-03 05:43 AM
Hi @GaborNovak,
I would recommended checking the sensor itself for any damage and reseating the sensor into the sensor port.  I would also recommend making sure that the NetBotz 250 is upgraded to the latest firmware version.
If you still experience this issue after checking the sensor and upgrading, you can reach out to technical support for assistance with the NetBotz issue.
Cory
