NetBotz 150 has survilance support?
  • NetBotz 150 has survilance support?
127
65
Posted: ‎2020-07-04 05:15 PM . Last Modified: ‎2024-04-04 11:58 PM
815
i want to add surveillance system in my data center that integrated with NetBotz 150 please help me out?
(CID:130683396)
  • NetBotz
815
Hi Abdul.
First, the NetBotz 150 is a sensor pod. There is no camera and it can not be used in surveillance.  The NetBotz 160 camera pod would need to be used in conjunction with a base NetBotz 4xx or 5xx device. The 355 has an onboard camera but can not connect to a pod.
Please also note that neither sensor pod nor camera pod are IP addressable. You can not put them on the network by themselves. They must have a compatible NetBotz appliance to which they are connected.
Steve.
(CID:130683402)
816
Hi Abdul.
Steve.
(CID:130683402)
ok
Thank you.
(CID:131961105)
Posted: ‎2020-07-04 05:15 PM . Last Modified: ‎2023-10-22 03:11 AM
