Posted: 2020-07-02 05:19 PM . Last Modified: 2024-04-09 02:30 AM
When using NFS as a Repository it appears that the software uses only UDP (seen in packet trace when negotiating with the NFS server). Is there a way to change it to use TCP?
(CID:104173909)
Hi Rob,
Are you referring to DCO or DCE? I can say that for DCE, there is no way to change the configuration or how we communicate with NFS.
Steve
(CID:104173911)
Yes, That would be for Data Center Expert. Is it possible to create a nfs mount in the OS (using TCP) and then use that mount point as a repository? Or are repositories only Cifs NFS (not fs).
thanks.
(CID:104173938)
Hi Rob,
I spoke with engineering and this is actually an option they are planning for the next version 7 release. This should be out by the end of the year but don't quote me on the timeframe, that's only an estimate.
Steve
(CID:104173939)
Steven; Would you know if there would be a future option for using Amazon S3 as repository?
(CID:104174571)
Hi Rob,
I checked here:
https://aws.amazon.com/storagegateway/
It looks like it can use either cifs or nfs. I don't know that we will be testing specifically against the Amazon S3 and I have heard nothing about this specifically but I'm assuming it should work as other operating system trying to use it do. If you can connect with a Windows or Linux system without specific software required on the OS, we should work similarly.
Steve
(CID:104174574)
Posted: 2020-07-02 05:19 PM . Last Modified: 2023-10-31 11:27 PM
