Posted: 2020-07-03 04:32 PM . Last Modified: 2024-04-08 12:36 AM
(CID:119638024)
Hi Haider,
You or your client need to contact your local Technical Support in order to validate their Software Support Contracts, and receive the upgrade links. The customer must have a valid support contract in place in order to receive these links.
Regards
(CID:119638056)
Just to add to John's comment, the licenses won't be lost. You can always use these keys on this server. An upgrade maintains the licenses. A restore would require that you have a copy but the customer should have a login to the https://dcimassets.schneider-electric.com/ site and if not, tech support should be able to assist.
(CID:119638125)
Posted: 2020-07-03 04:32 PM . Last Modified: 2023-10-22 03:05 AM
