Posted: 2020-07-02 12:11 PM . Last Modified: 2024-04-09 11:56 PM
I know that what i am asking is a lot, but i wish that dco and the other apcs product get some work on their apis done to better integrate with all other products by utilizing a basic but robust restful interface which i think will expand the possibilities of dco.
I have Data Center Operations managing various sites across the country and i am trying to get and update data on DCO through each sites own webpages portals which also track other site information. I will make displays with site current power, space, cooling information, add equipment to a rack or edit a rack equipment.
We tried to get ETL working but it has been a pain and the soap interface seems to only let you consume data and not post/update new one plus the xml file generated by it are note the best way to consume the data by modern web services.
I will like to ask if there are plans or if not to consider it to ask a simple modern RESTful API to DCO, maybe if i am lucky to DCE to, that supports the basics operations of:
And which can server and consume data as either xml or json and allow cross-domain request (Data could be displayed with a simple HTML/JavaScript webpage with no need for server side programming).
As an example:
API endpoints:
/items
Would let your work with all devices/racks/inrows/etc it will let you query information from them or add a device. for example get all devices on a room with id roomId
http://dco_ip/rest/items?room_key=roomid
and also limit the fields that are returned to decrease the size of the object ask for in this one only pull selected fields:
http://dco_ip/rest/items?room_key=roomid&field=key&field=lastModified?field=name
Maybe some way to only get items modified on a certain range that way a client doesn't have to check a items to update itself.
http://dco_ip/rest/items?room_key=key&,modified=(dateTimeUTC)
All of the previous one would be Get request, the format asked for could be by default xml but if the header or a parameter could be set to obtain json.
/rooms
same format as items but for all the rooms on a device user folder_key instead of room_key.
/locations
obtain all folder/locations under which a room can be on with parameters to filter the data.
/genome
be able to see the genome library data that way i could maintain a centralized device database that other services could feed from.
/psc
be able to supply an id and obtain power space and cooling information for that id examples:
http://dco_ip/rest/psc?id=roomId
Will get me capacity utilization, max historic, maximum capacity etc..for a room
http://dco_ip/rest/psc?id=itemId
will get me the same but for an item maybe port utilization instead of space
http://dco_ip/rest/psc?id=location
The same as room but for a whole folder/location.
/query
pass an id to get the information about the item specified it doesn't matter if it is a genome, item , location, room.
http://dco_ip/rest/query?id=roomId
will give the same result as:
http://dco_ip/rest/room?id=roomid
Also XML and Json Format please be simple with no namespaces if possible:
XML(CID:96044038)
Hi John,
Thanks for your well thought out suggestion!
We are actually working on transitioning from internal (and a handful of public) SOAP web services to a public RESTful API with JSON responses. This won't happen overnight, but in future versions, you should see more and more functionality exposed through REST services. We are working towards a point, where anything you can do with the DCO client can be done through a public REST service.
I've forwarded your input to the people working on this. I'm sure they will find it useful.
Torben
(CID:96044148)
Hi James, We are very much aware of the webservice API for our DCIM products needs some work done. We will get back with some more details.
(CID:96044052)
Hi John,
Torben
(CID:96044148)
Awesome job on the new web api, are there any plans to expand it.
I have a few questions/concerns.
(CID:106210686)
Posted: 2020-07-02 12:11 PM . Last Modified: 2023-10-31 11:22 PM
