Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-05 02:07 PM . Last Modified: 2024-04-04 12:16 AM
Good day
I want to know how is the procedure to migrate and update DCE AP9465 to VM DCE and move to the latest version. Please, your help as this information is not common (one video).
Thank you,
Leonardo Suárez
(CID:135433883)
Hi Leonardo,
you’ll need to contact your local tech support team directly to start this procedure as they will need to provide you with new license keys. The keys are tied to the server MAC address (assuming you have more than the default 25) and you need supports assistance for this.
Steve
(CID:135434404)
Thank you, I have other question...
I have one costumer that have DCE 7.4 and they need to know if possible use IPV6 in your network card AP963X and that DCE can comunication throught about this protocol IPV6 (SNMP). Moreover, they want to know if is possible that the DCE can have one IP direction with IPV6 protocol (own network LAN private and/or public), as that the network card have this protocol (IPV6) but would be singular that DCE can not access to them because generally DCIM is operating with IPV4 .
Thank you
Leonardo Suárez R. from Colombia
(CID:140712602)
Posted: 2020-07-05 02:08 PM . Last Modified: 2024-04-04 12:16 AM
Dear Leonardo Suarez,
As far as I know, the DCE-7.x appliance itself (although it is based on CentOS) does not know how to address IPv6 addressing (both in private and in public LANs).
Perhaps sometime this will be implemented: I can only recommend to make a corresponding Feature requests.
If you have more questions, please, have fun.
With respect.
(CID:140712606)
Please, tell us if you could solve this question or not?
With respect.
(CID:137103291)
This question was solved.
Thank you
(CID:140712343)
Ok, very thanks for the good feedback 😀.
(CID:140712376)
Posted: 2020-07-05 02:08 PM . Last Modified: 2023-10-22 03:02 AM
