Posted: 2020-07-04 08:51 PM . Last Modified: 2024-04-04 04:02 AM
Hi, I want to clarify that I can change the format of output information from device. And I must write another type like that
Am I right?
Thank you for answers
(CID:132669250)
Dear Dmitry Emelyanov,
The latest version of DCE-7.5.0 software knows only such standard units of measurement of the speed of movement of air or liquid:
Therefore, for air it should be like this:
num literspermin
or
num literspersec
And, for a liquid it should be like this:
num fluidliterspermin
The standard unit of measure m3/h above the specified DCE software is not supported ☹️. Instead, several other units of measurement are supported:
You can create the corresponding Feature requests, and it is possible that this will be implemented, for example in future versions of DCE software. I, for one, hope so too 😀.
With respect.
(CID:132669272)
num literspermin
or
num literspersec
With respect.
(CID:132669272)
Thank you, it's very helpful
(CID:132669279)
Ok, thanks for the good feedback 😀.
(CID:132669289)
Posted: 2020-07-04 08:52 PM . Last Modified: 2023-10-22 03:02 AM
