Posted: 2020-07-04 11:13 PM . Last Modified: 2024-04-04 02:37 AM
Is it possible to associate measured data with a DC Power Plant in DCO? Does predicted power work when using DC Power?
(CID:134029443)
Hi Robert,
Would you mind to add more details about modeling "DC Power Plant" in DCO.
I had a quick look at the searched images from Internet, and wondering if the intention is to model them in DCO, then unfortunately that's not supported.
In DCO, currently DC power path/modeling is limited to Data Center and may not cover all DC devices/equipment.
But from the general point of view, if you have supported power path/model in DCO, then it should be possible to associate a DC device (from DCE) to it's model in DCO. The same goes for the Predicted Power/Estimated load strategy, it is general in DCO (for whole setup), eg. both for AC and DC power path.
Kind regards
(CID:134029664)
Hi Robert,
Kind regards
(CID:134029664)
Thank you Jeff! I am not all that familiar with the DC power path at this point but the big concern was associating metered data with the modeled data which you answered.
Thanks again,
Bob
(CID:134029761)
Posted: 2020-07-04 11:13 PM . Last Modified: 2023-10-22 03:01 AM
