Posted: 2020-07-02 03:31 PM . Last Modified: 2024-04-09 03:08 AM
Hi All ,
I just monitor two rPDU in DCE and associated to DCO , I found the measure data didn't match DCE ,
Pls see attachment and kindly advise. Thank you .
Best Regards
(CID:102924691)
Posted: 2020-07-02 03:32 PM . Last Modified: 2024-04-09 03:07 AM
Hi Chu Li,
The difference is that Data Center Expert is a monitoring tool. This means that it is used for monitoring real-time values. Data Center Operation on the other hand is a planning tool. For planning is real-time values not useful.
Instead does Data Center Operation relay on average data and KPI data collected over time. So you can not directly compare the data from Data Center Expert with the data in Data Center Operation.
Jesper
(CID:102924697)
Hi Jesper , Thanks for advise ,if so , do you know how DCO calculate this measure data ? Thanks . Best Regards
(CID:102924725)
Hi Chu Li, Here is some information about KPI/Measured data in Data Center Operation. http://dcimsupport.apc.com/display/UAOp74/Capacity+History+%28KPI%29+Description Thanks Jesper
(CID:102924749)
Hi Chu Li!
This info can be helpful for you:
(CID:102924795)
Hi Valentin , Thanks for kindly help , Now just waiting for DCO update the value ,thank you . Best Regards
(CID:102924905)
Posted: 2020-07-02 03:32 PM . Last Modified: 2023-10-31 11:21 PM
