Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
Mac OS Catalina with DCO
  • EcoStruxure IT forum
  • Mac OS Catalina with DCO
126
65
Back to EcoStruxure IT forum
NF-London
Ensign NF-London
Ensign
Posted: ‎2020-05-18 09:52 AM
2175
A user has been having difficulties loading DCO (8.2.2) desktop client.  He has recently had to upgrade his laptop and is using MAC OS "Catalina".  Is this version compatible?
  • Data Center Operation
Shaun
Commander Shaun Commander
Commander
Posted: ‎2020-05-22 04:35 AM
In response to NF-London
I just tried the 8.2.2 client on macOS Catalina (10.15.4) successfully.  The error you're seeing is from changes in the code-signing workflow, where this client build predates them.
You should be able to bypass them by opening the Applications folder, right-clicking (or control-clicking) the DCO application, and selecting Open from the context menu.  This only needs to be done once (or each time the DCO application is updated).
ref: https://support.apple.com/en-us/guide/mac-help/mh40616/mac
Replies 6
Admiral
Posted: ‎2020-05-18 11:58 PM
2161
Hi Nigel,
I have heard some MAC users having similar issue, that seems to be java related. user might want to try installing Java Legacy 1.6 for MAC OS and see if that helps.
Kind regards,
NF-London
Ensign NF-London
Ensign
Posted: ‎2020-05-22 03:30 AM
In response to Jef
2149
The user is reluctant to downgrade his Java which I think is higher at 1.7 or something.  The error appears as attached.  I think in this case we will have to pursue the upgrade and hope that once we migrate to ITA this user can continue to use the desktop client or be satisfied with the larger feature suite in the web client.  He is a read/write user.
Shaun
Commander
Admiral
Posted: ‎2020-05-22 04:45 AM
2134
Hi Nigel,
Many thanks for the screen shot - that doesn't seem to be java related, but privacy related.
You/user might want to try a) go to System Preferences > Security & Privacy and click on Open anyway (or something like that), and or b) try the option Shaun has kindly shared.
Kind regards
NF-London
Ensign NF-London
Ensign
Posted: ‎2020-06-04 12:44 AM
In response to Jef
2092
The User has told me this morning he has moved platforms and is using Win64 now.
Admiral
Posted: ‎2020-06-04 01:17 AM
Hi Nigel,
Many thanks for the update - so assuming user have already downloaded and installed the windows based DCO client software.
Kind regards
