MODULYS GREEN POWER (20-360 kVA)
  • EcoStruxure IT forum
  • MODULYS GREEN POWER (20-360 kVA)
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:54 PM . Last Modified: ‎2024-04-05 12:25 AM
779
is it possible to integrate "MODULYS GREEN POWER (20-360 kVA)" into struxtureware and how?
(CID:129412960)
Dear ADEKUNLE AGBOKE,
It looks like you are lucky 😀 and your equipment is already supported by DCE software. Here is a screenshot from Device Support:
All you need is to press the button I WANT IT TOO and within one business day you will be sent a web-link to download the corresponding DDF-file with the instruction.
I hope this is what you need.
With respect.
(CID:129412976)
Replies 5
779
Dear Adekunle,
You can discover a device if it supports SNMP or Modbus Over TCP protocols to Struxureware Data Center Expert software.
Please refer the below K-base video on how to discover the device to DCE software.
https://www.schneider-electric.co.in/en/faqs/FA177081/
In order to add this device and view the parameters if it supports SNMP or Modbus Over TCP, then you will need to request for Device Definition File(DDF). Please refer the below link to see if you device is already listed. If not, please request for a new DDF request with the details.
http://sxwhelpcenter.ecostruxureit.com/devices
I hope it helps.
Bala
(CID:129412971)
Thanks Bala,
once i have the Device Definition File(DDF) i will do that.
(CID:129413404)
With respect.
(CID:129412976)
Tell us please, could you solve this problem or not?
With respect.
(CID:132646804)
Posted: ‎2020-07-04 03:55 PM . Last Modified: ‎2023-10-22 02:59 AM
