MIB file for E4 LCD Pro 3000 S INFOSEC
  • MIB file for E4 LCD Pro 3000 S INFOSEC
129
72
Posted: ‎2020-07-05 11:11 PM . Last Modified: ‎2024-04-03 12:13 AM
1332
Does anybody have the MIB file for E4 LCD Pro 3000 S , Infosec Brand ?
or tell me how can I get this file to make a DDF request?
Thank you in advance for your help!
(CID:151061585)
  • IT Expert
Dear Marcel Martinez,
Try to first discover your E4 LCD PRO 3000 UPS in DCE software without any additional DDF-file. It is very possible, that your E4 LCD PRO 3000 UPS will be discovered and its sensors will even be visible (this is done using the standard UPS MIB DDF-file in the DCE software).
If you only need a MIB-file, then I highly recommend, that you contact the official INFOSEC UPS System manufacturer with this question. This is the only right solution.
Hope this helps you.
With respect.
(CID:151062266)
Replies 4
With respect.
(CID:151062266)
1332
Thank you I will try if doesnt work I will write back.
(CID:151064367)
Ok, very thanks for the good feedback 😀.
(CID:151064598)
Posted: ‎2020-07-05 11:11 PM . Last Modified: ‎2023-10-22 02:59 AM
