Posted: 2025-05-20 05:53 AM
Hello all,
I have been updating our Netbotz rack monitors and so far when I come from 5.2.1 to 5.4.1.5027 (via 5.3x) I have lost access to the GUI both times.
I've run the commands to clear the database, restart clubber, and even factory reset but I can't seem to restore the web GUI. The only access I have is SSH.
I noticed that prior to the update there were three files in the landing folder (/home/root😞 config.ini, config.ini.backup and ddf.zip. Post update there is only ddf.zip and nohup.out.
config.ini contains the general settings including network and SNMP details. Is it helpful to edit that file from a working monitor and replace it there?
Or is there a better way to restore the GUI?
Posted: 2025-07-02 03:12 AM
EMEA Tech Support helped me resolve this.
Clearing the database and factory reset didn't help.
The solution was to revert to the last working firmware:
run flip_banks
boot
In one case that was an end of it.
In the other I was left with 503 errors on the web GUI but that was resolved by clearing the database.
Posted: 2025-05-21 03:31 AM
Also, I wondered - without the web GUI - is there anyway to roll back the last upgrade?
Something like active partition options where the previous version is in the other partition.
Posted: 2025-05-22 09:44 AM
Hello @Hogg
You'll get the best and fastest results if you contact support for help with this issue.
Posted: 2025-05-23 01:23 AM
Thanks.
I'm waiting on a response there already.
Posted: 2025-06-09 02:22 AM
Hello @JLehr,
How long is it usually before a support ticket gets a response?
I gave it a nudge comment after a week or so but still nothing and that was a week ago.
Is calling them possible/better?
Posted: 2025-06-10 05:57 AM . Last Modified: 2025-07-03 06:14 AM
Hi @Hogg,
Yes, please contact your local support again. It will help to have your support ticket number available.
It's unusual that you'd be waiting so long. Apologies for that.
Posted: 2025-06-10 06:08 AM
Thanks. Will do.
run flip_banks
boot
