Lost Connection between DCE and DCE error
  • Lost Connection between DCE and DCE error
129
72
Posted: ‎2020-07-05 08:52 PM . Last Modified: ‎2024-04-03 01:03 AM
889
Hello
We got the flowing errors a lot of time in day .
We have raised the timeout and others value too .
In additional I upload the log file from dcserver.logo .
(CID:147196970)
  • Data Center Operation
Replies 5
Posted: ‎2020-07-05 08:53 PM . Last Modified: ‎2024-04-03 01:03 AM
Hello Boris. Was this issue resolved?
Regards
Greg Sterling
(CID:147199617)
Hello Greg
Unfortunately the problem didn't solve
(CID:147199794)
Greg Sterling Can you please help Boris if possible? Thank you
(CID:147200609)
Boris. I assume "testing" to the DCE server from the DCO server works?
You noted you increased the timeout values in the below screen. Is 600 seconds the maximum value you've used?
If yes, please increase this value to something much greater, like 1800 seconds. I'm going to direct email you some instructions for setting some debug information on the DCE server so we can see if DCE will tell us how long the query from dce is actually taking.
Also, if the query from DCE is taking a while, over 600 seconds for example, then you may want to consider increasing the polling time settings in the top portion of this panel. If DCO is polling DCE for device and power data every 5 mins (300 seconds) as stated in your screenshot but DCE is taking over 10 mins (600 seconds) to respond, then DCO is repeatedly asking for data from DCE faster than it can provide a response.
Looks for an email from me shortly.
Regards
Greg Sterling
(CID:148767686)
Posted: ‎2020-07-05 08:53 PM . Last Modified: ‎2023-10-22 02:58 AM
