Login page disappeared
  • Login page disappeared
129
72
Posted: ‎2020-07-05 07:40 PM . Last Modified: ‎2024-04-03 02:34 AM
1205
Hello, I'm having an issue with the Portal's login page. I've just removed the Welcome page but the Login one was gone instead. Now I can't log in and I can't modify the page.
Is there a way to reset the Portal webpages and configurations or anything else to do?
Regards!
EDIT: I resolved it, but now some bars disappeared, for example:
Plus, I can't select new templates. It seems that have been erased, don't know why.
(CID:144311891)
  • Portal
1205
Hi Javier,
It is not clear from your screen captures what might be missing/disappeared - is it the administration menu such as "Add portlets", "Add", "Manage" etc.
There is no reset option in Portal, I would recommend a clean re-installation.
Kind regards
(CID:144312101)
1206
Hi Javier,
Kind regards
(CID:144312101)
The both "StruxureWare" and "Pages" bars are not showing up. Neither the administration menu.
(CID:144312332)
Posted: ‎2020-07-05 07:40 PM . Last Modified: ‎2023-10-22 02:57 AM
