Posted: 2020-07-03 07:55 AM . Last Modified: 2024-04-08 04:02 AM
We have an internal intranet page where we would like to display some live data from the DCE server (such as temperature)
Does anyone know if it is possible to display this data within a webpage?
Matt
(CID:110005038)
Hi Matt,
You should be able to achieve this using the DCE Web Services API discussed below.
https://dcimsupport.apc.com/display/public/UADCE725/StruxureWare+Data+Center+Expert+Web+Services+API.
You can download it from the link below.
http://www.apc.com/shop/ie/en/search?Dy=1&Nty=1&Ntt=SFWEBSVC
Regards
(CID:110005045)
Hi Matt,
Regards
(CID:110005045)
Hi Matt
I assume you've checked out the DCE Web Page e.g. http://isxc.apc.com and StruxureWare Portal https://dcimsupport.apc.com/display/public/Portal/StruxureWare+Portal which I think you should be able to use even if you don't have DCO.
Cheers
(CID:110005133)
I think the API is better suited for what we need to do. But this looks like it could be interesting. Will also look at it. Thanks!
(CID:110005176)
Posted: 2020-07-03 07:55 AM . Last Modified: 2023-10-22 02:57 AM
