Posted: 2020-07-04 02:54 AM . Last Modified: 2024-04-05 03:41 AM
Hi team,
How many times a license can be activated? Is it possible to delete a license from a server and install on another?
May the Force be with you.
(CID:126880712)
Hi Alexander,
Usually the license registration/activation may happen once (might be tied to server MAC add.). However if for some reasons (such as hardware 'upgrade'/change) you might need to change the server, then you might need to contact the local tech support and ask for guide lines. thanks.
Kind regards
(CID:126880750)
As far as I know, the licenses are binded to your appliance/VM mac address.
(CID:126880747)
Hi Alexander,
Kind regards
(CID:126880750)
Thanks useful
(CID:126885454)
Posted: 2020-07-04 02:54 AM . Last Modified: 2023-10-22 02:55 AM
