Is there anyway to add a login message?
  • Is there anyway to add a login message?
129
72
Posted: ‎2020-07-03 09:53 PM . Last Modified: ‎2024-04-07 11:33 PM
874
I'm trying to add a user generated login message to StruxureWare DCE when users try to login.  Is this even possible?
Thank you
(CID:123348868)
Hi Brett,
The login screen is not editable and there is no way to create a popup after a valid login to DCE. At the top of the page here, there is an option for a feature request. You can try adding one.  I will say that this is the first request I've seen of this type so I can't say what kind of traction such a request will have.
Steve.
(CID:123348875)
Hi Brett,
Steve.
(CID:123348875)
Posted: ‎2020-07-03 09:54 PM . Last Modified: ‎2023-10-22 02:51 AM
