Is the DDF file for InRow ACRC301H the same as the .DDF for ACRC301S ?
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • Is the DDF file for InRow ACRC301H the same as the .DDF for ACRC301S ?
124
110
65
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-02 11:33 AM . Last Modified: β€Ž2024-04-10 12:13 AM
1162
Is DDF file for InRow ACRC301H the same as .DDF for ACRC301S ?
Tx
(CID:95355399)
Replies 12
Hi Parrot, thanks for posting! @community-any experience with DDF files? If yes, go ahead and share with us your experience/insight. Thanks!
(CID:95355566)
1162
Hi Parrot,
To my understanding there are no specific DDF files for the products hence the DDF should be the same. At least there is general "*ACRC*" DDF file available which will cover these devices.
Are there any specific data from one of the devices that you would expect to see that should not be available from the other?
(CID:95355588)
Hi Soren,
I have installed the DDF for ACRC301S and globally it seems working fine for ACRC301H. I've to go deeper to see how are managed the differences.
ACRC301S uses a condensate pump. ACRC301H has no condensate pump but a Dew pump to avoid condensation issues.
(CID:95355779)
Curious. Where did you find this DDF? Trying out StruxuWare 7.2.6 but with default files it just shows up as a cooling device and I can't see any real read out from it. Can you point me at a link to it?
(CID:96764313)
1162
Hi Henrik,
I don't remenber where i found the DDF, I guess thru the community/schneider sites/google! Obviously not easy to find ddf files, but I can send it to you. Let me know.
(CID:96764319)
Hello Please do! I've given up on finding something at their site looooong ago. πŸ˜ƒ henrik_at_filmlance_dot_se Thanks =)))
(CID:96764320)
Hi Parrot and Henrik, Ouch, sometimes the truth hurts, but you are right; finding DDFs is currently painful to say the least. You will be happy to know that we are working on making all DDFs and Genomes available directly from DCIM Support in the future. Stay tuned πŸ™‚ Best, Kristoffer Debois DCIM Support
(CID:97484834)
Posted: β€Ž2020-07-02 11:34 AM . Last Modified: β€Ž2024-04-10 12:13 AM
Hi All,
I am from the DDF Team. We have two DDF files with us "schneider_acrc301.xml" and "schneider_acrc301s.xml".
Both the files are almost same, except "schneider_acrc301.xml" has two extra sensor points,
  1. Delta-T Setpoint - OID(.1.3.6.1.4.1.318.1.1.27.1.5.2.2.1.4.1.3)
  2. Alarm on Standby - OID(.1.3.6.1.4.1.318.1.1.27.1.5.2.2.1.4.1.19).
Let me know if you need any other details regarding this.
(CID:104175005)
1162
Hello, Where can we find the "schneider_acrc301.xml" file? Currently i'm using "schneider_acrc301s.xml" for 301H InRow. Regards
(CID:105458806)
Please find the attachment
(CID:105458809)
Don't get attachment file ...
(CID:105458812)
Posted: β€Ž2020-07-02 11:34 AM . Last Modified: β€Ž2023-10-31 11:18 PM
