Posted: 2020-07-05 08:46 PM . Last Modified: 2024-04-03 01:06 AM
We have used SCP since about version 7.4 or 7.5. Anyways since upgrading to 7.7 we seem unable to pull device configs using SCP. it works fine if we use FTP but not SCP
(CID:147196215)
Posted: 2020-07-05 08:47 PM . Last Modified: 2024-04-03 01:05 AM
Hi Daniel,
This may be a known issue depending on the device firmware. Please check out the following k-base document:
http://www.apc.com/us/en/faqs/FA274541
Steve
(CID:147196569)
Steve thanks for responding, but all of our devices are on the most up to date firmware. as i said in the OP we have been using SCP for several versions of DCE. So, for a while we have been successful with using it. it wasn't until we upgraded to 7.7 that SCP is no longer working on any devices
(CID:147196590)
Posted: 2020-07-05 08:47 PM . Last Modified: 2023-10-22 02:48 AM
