Invalid Certificate with DCE trial version over Vmware vsphere
  • EcoStruxure IT forum
  • Invalid Certificate with DCE trial version over Vmware vsphere
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 12:00 AM . Last Modified: ‎2024-04-04 01:14 AM
764
I got an error when installing DCE trial version over Vmware vsphere Ver 6.5.0.13000.
¿Do you have a clue to solve it ang go on with next steps?
(CID:134035705)
  • IT Expert
Posted: ‎2020-07-05 12:01 AM . Last Modified: ‎2024-04-04 01:14 AM
764
It will work if you use the HTML5 client instead of the vSphere flash client.  It will still give you a warning but you should be able to deploy it.
(CID:134035710)
Replies 4
765
(CID:134035710)
This issue can also be found within the knowledge base: http://www.apc.com/us/en/faqs/FA358901/
(CID:134035724)
Amazing: Tks
(CID:134035810)
Posted: ‎2020-07-05 12:01 AM . Last Modified: ‎2023-10-22 02:47 AM
