Posted: 2020-07-02 10:46 PM . Last Modified: 2024-04-09 01:21 AM
Hi All!
In DCO client's system requirements noted that DCO 7.5 supports Internet Explorer v9 and higher.
Our customer requires support for IE8 and I suppose that DCO will work fine with it.
Is there any critical issues with IE8?
(CID:105461402)
Reports require Internet Explorer 9 or later to work correctly.
Please note that Microsoft has just ended support for Internet Explorer older than version 11, see https://www.microsoft.com/en-us/WindowsForBusiness/End-of-IE-support
(CID:105461404)
(CID:105461404)
Posted: 2020-07-02 10:46 PM . Last Modified: 2024-04-09 01:20 AM
Thank you!
(CID:105461408)
Hi Valentine,
Please notice that DCO is using the default browser engine to display the reports on screen, and therefore you need IE version 9+ (for Win.) to render reports correctly in the application.
And I believe IE8 itself is outdated & unsupported by Microsoft .
Hope this helps,
Kind regards
(CID:105461406)
Thank you!
(CID:105461409)
Posted: 2020-07-02 10:46 PM . Last Modified: 2023-10-31 11:10 PM
