Installing DCO to new server.
  • Installing DCO to new server.
129
72
Posted: ‎2020-07-03 03:54 PM . Last Modified: ‎2024-04-08 12:48 AM
1128
Hello Jef Faridi
Pls check the screen-shot while installing DCO to new server im facing this error.
Pls if you can support or any solution you have got ?
Thank-you
(CID:118002399)
  • Data Center Operation
  • bug
Replies 7
Hello Waseem. Can you describe the hardware on which you're installing DCO? If its a VMware guest, is the OS type set to CentOS in the guest definition?
Regards
Greg Sterling
(CID:118002424)
Posted: ‎2020-07-03 03:55 PM . Last Modified: ‎2024-04-08 12:48 AM
1128
Hi Waseem,
It seems to be hardware related that the installer OS doesn't seem to support.  What is the spec of this server? and the DCO version you are trying to install?
If you are not using 8.1 installer already, then please try that - since 8.1 is shipped with an updated CentOS and it may help, thanks.
Kind regards
(CID:118002436)
Jef Faridi Thank you jef
I'm using CISCO UCS-C220-M3S server
DCO verison 8.0.2
But I'm not sure whether it has the updated cent OS or not ?
Pls share the latest download link which comes with updated CentOS (iso image ) i will try that ?
Regards
(CID:118002468)
Hi Waseem,
Many thanks for the info - I would suggest trying the latest release, currently 8.1
the current process for getting the download link is via contacting the local tech support, but please be aware that they may need to verify customer support contact, thanks.
Kind regards
(CID:118002535)
Greg Sterling Thank you for your reply
The server is Cisco UCS-C220-M3S
And we are  installing through ISO file
This is not VM-ware
Kindly suggest ?
Regards
(CID:118002449)
Hi Waseem Khan and Jef Faridi,
I also became interested in the above mentioned problem and can confirm, that the installation images of the DCO (even the current version of the DCO-8.1) simply do not support UEFI-based BIOS.
I can assume, that the DCO developers primarily focused on the VMware virtualization, where the de facto standard for virtual machines is just legasy BIOS mode, instead of UEFI. Therefore, all the extra rpm-packages from the original OS CentOS-7.3 were simply removed, including the rpm-packages for supported UEFI-based systems.
Thus, it is not exclusively a problem of a server, such as CISCO UCS-C220-M3S. And if the server (for example, CISCO UCS-C220-M3S) allows you to switch the legacy BIOS mode, then the above problem can be simply bypassed and successfully installed DCO.
With respect.
(CID:118002918)
Posted: ‎2020-07-03 03:55 PM . Last Modified: ‎2023-10-22 02:46 AM
