Installing DCO 8 with HP DL380 Gen9
  • EcoStruxure IT forum
  • Installing DCO 8 with HP DL380 Gen9
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 06:25 AM . Last Modified: ‎2024-04-08 10:48 PM
958
Hi Team,
We are proposing DCO 8 setup on HP DL380 Gen9 E5-2609v3 with Smart Array P440ar/2G Controller. As of previous experience as listed in the link below:
https://dcimsupport.apc.com/questions/103583979/answers/103584002/comments/103584037?queryString=dl3...
DCO 7.5 was unable to install on the physical server. Can someone suggest if DCO 8 supports installation on this physical server?
Thanks and Regards,
TJ
(CID:108826733)
  • Data Center Operation
957
Hi TJ, I had a System ,ML350 P9 with smartarray p440ar, and was not able to install DCO 7.5 but installing DCO 8 was no problem, just before the release of DCO 8 engineering also provide me this answer :We have just tested Centos 7.2 (DCO 8.0) on a HP DL 380 Gen9 server and the installation went fine. Raid controller is P440ar, the same as in the ML 350 Gen9.
(CID:108826755)
Replies 6
958
(CID:108826755)
Thanks for the feedback Cees de Vogel !
(CID:108826776)
Cees de Vogel My customer has the same hardware configuration. For some reasons, I may not convince them to install DCO 8.0 for an upcoming DCO expansion since the consultant only approved version 7.5 at the moment. Is there anyway that I can tune the Debian to support DL380 Gen9 for DCO 7.5? I have OK experience in Linux and should be capable to give a try for script-based / dos command solution? Just want to hear your feedback. Thanks
(CID:108828369)
Winnie Chau This is not something I can help you with, this is something development in Kolding has to answer, sorry 😞
(CID:108828403)
Cees de Vogel , oic. Thank you a lot anyway.
(CID:108828501)
Posted: ‎2020-07-03 06:25 AM . Last Modified: ‎2023-10-31 11:10 PM
