Impossible to insert blade BL460C G9 in C7000 G3 enclosure
  • EcoStruxure IT forum
  • Impossible to insert blade BL460C G9 in C7000 G3 enclosure
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 09:04 PM . Last Modified: ‎2024-04-04 03:58 AM
1092
Impossible to insert HP Proliant BL460C G9 blade in all enclosure HP C7000 G3 for StruxureWare Data Center Operation (Version : 8.2.7-77203-e6c65c).
Is-it normal ??? For solution we copy and paste a blade already in enclosure.
Thanks for your help
(CID:132670969)
  • Data Center Operation
Posted: ‎2020-07-04 09:04 PM . Last Modified: ‎2024-04-04 03:57 AM
Hello ,
Thanks for your help. I had "Bladesystem C7000 Enclosure G3" in Family properties and it's OK !
(CID:132671218)
Replies 4
Hello Jego
If you check the properties of the bl460 g9 blade. Make sure the general page, family section (circled below) includes the G3 chassis you mention in your post. That field contains the names of the chassis in which the blade is allowed to be placed.
We can separately submit a request to the genome team to update existing blades to include the G3 chassis already.
Regards
Greg Sterling
(CID:132671095)
To be specific, make sure you paste the info from the G3 chassis product family view in its properties into the family section of the G9 blade properies.
In this case you'd paste "C7000 Enclosure" into the family pane for the BL460 G9 blade.
Regards
Greg Sterling
(CID:132671097)
Hello ,
(CID:132671218)
Posted: ‎2020-07-04 09:04 PM . Last Modified: ‎2023-10-22 02:42 AM
This is a heading
