Import options
  • EcoStruxure IT forum
  • Import options
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 02:13 PM . Last Modified: ‎2024-04-09 04:16 AM
531
Import options
Hello!
I am wanting to import data into DCIM from Excel and have followed the video but in my file>import menu, the option doesn't exist. Is there a setting I am missing somewhere?
Thanks!
Tyler
(CID:99157134)
530
You need logout of your client, remove the "#" from the below line in your 'StruxureWare Data Center Operation.ini', and restart your client.
-Dexcel.importer.enabled=true
The path for this file may vary, but below example should get you there:
:\Program Files\StruxureWare Data Center Operation 7..\application
-Jeff
(CID:99157136)
You also need to click on "Planning" icon to get out of normal Read-Only mode to see the Import menu, once you are in the client.
(CID:99157141)
Posted: ‎2020-07-02 02:13 PM . Last Modified: ‎2023-10-31 11:08 PM
