Posted: 2020-07-04 08:03 PM . Last Modified: 2024-04-04 04:20 AM
Hello
Does DCO version 8.2.2 or 8.2.7 is supporting SSO with Windows Active directory2012 ?
If yes - how I can configure it
Thanks in advance
(CID:132662928)
Hi Boris,
This guide explains how to configure it.
(CID:132662944)
Posted: 2020-07-04 08:04 PM . Last Modified: 2024-04-04 04:20 AM
Hello Davis
Many thanks for your answer .
In the link that you sent I didn't see that relevant to Implementing Single Sign-On on DCO .
One point maybe relevant - that implement AD certificate into DCO .
Does this enought for the Single Sign-On ?
(CID:132663134)
hello Jef
Really I dodn't understand is this supporting or not ?
Does configurate ssl options (add certificate ) implement the SSO ?
(CID:132663999)
Hi Boris,
Single Sign On (SSO) is currently not supported in DCO.
AD/LDAP server(s) can be used as authentication server in DCO (for remote users). The authentication server settings in DCO supports both unencrypted and encrypted (ssl) communication.
The ssl option dose not implement sso, as mentioned sso is not supported.
Kind regards
(CID:132664007)
Hi Boris,
Single Sign On (SSO) is currently not supported!
Kind regards
(CID:132663019)
Posted: 2020-07-04 08:04 PM . Last Modified: 2023-10-22 02:42 AM
