Uploading backup file in webmin
Select a Country
  • Uploading backup file in webmin
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 08:04 PM . Last Modified: ‎2024-04-04 04:20 AM
1792
HI Jef Faridi
I'm trying to upload the backup file via webmin and its taking too much of time
the first stuck was when in choose file option i selected the .tar file it took 20 minutes to display that file and the second step when i clicked on the upload tab the upload status bar was completed successfully quickly but now it gets stuck on the same page and if you check below on the page it says waiting for then the IP and it doesn't redirects to the next page where you can see upload to the server is complete and successful its been almost half an hour now its stuck here.
could you please tell me what could be the reason where is the issue exactly ?
Regards
(CID:132663472)
  • Data Center Operation
  • IT Advisor
DCIM_Support Mentor
Mentor
1791
Hi Wassem,
I guess you might have a very large backup file - so instead of web browser I would try using file transferring tools such as WinSCP. WinSCP is a free and open-source tool, that can be downloaded from internet/https://winscp.net.
Kind regards
(CID:132663486)
Replies 4
DCIM_Support Mentor
Mentor
1792
Hi Wassem,
Kind regards
(CID:132663486)
DCIM_Support Mentor
Mentor
Jef Faridi Thank you jef
Yes that is actually the reason the file size
Well on a lighter note how did i skip winscp option its already installed in my system 😂
i have wasted my 2 hours on web browser
anyways thanks again
(CID:132663494)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 08:05 PM . Last Modified: ‎2024-04-04 04:20 AM
You are most welcome Waseem 😀
Kind regards
(CID:132663497)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 08:05 PM . Last Modified: ‎2023-10-22 04:13 AM
