ITO Server Power Data to the PUE Calculator
  • EcoStruxure IT forum
  • ITO Server Power Data to the PUE Calculator
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 10:05 PM . Last Modified: ‎2024-04-03 12:35 AM
675
Hi Team,
Kindly, one way of getting IT load if there are no intelligent pdu is to use the ITOptimize and get the server power consumption directly.
However how can I add this data to my PUE calculator on the IT load section.
Thanks.
(CID:148768449)
  • Data Center Operation
Based on some tests I ran this morning I would say its not possible to use ITO to feed power data from sensors to the PUE calculator. My ITO server does not appear as a source for sensor data for PUE.
I assume the power devices upstream from the racks are not monitored?
It is possible to use an ETL import database as the source for power data in addition to using a tool like data center expert. In this case though you'd need to come up with a mechanism to transfer power readings into the import database.
(CID:148770293)
Posted: ‎2020-07-05 10:05 PM . Last Modified: ‎2023-10-22 02:41 AM
