Posted: 2021-02-15 08:35 AM
Hi All
is it possible to export data from ITA to another software?
Customer wants to use some data from ITA to populate info to another software
Posted: 2021-02-16 04:45 AM
Hello Gianluca
This page from the help center describes the steps to create an ETL export database onto a SQL server database https://helpcenter.ecostruxureit.com/hc/en-us/articles/360007453917-ETL-export-to-MS-SQL-Server
ITA has a built-in servicenow connector for the servicenow cmdb. Information can be found here https://helpcenter.ecostruxureit.com/hc/en-us/articles/360037365533-ServiceNow-Asset-Management-Conn...
Information about the ETL export schema can be found here: https://helpcenter.ecostruxureit.com/hc/en-us/articles/360007339797-ETL-export-database
The above servicenow connector pulls data from servicenow into ITA. It should work with ITA 9.1.4 and newer releases. Customers wishing to update servicenow based on data in ITA would likely have to create an integration from the servicenow side so that data can be pulled into the service now platform from either ITA REST api's or pulling data from an ETL export database. Most customers wanting this type of integration do so with an engagement with our ACS (advanced customer services) team.
Posted: 2021-02-15 10:12 AM
Hello Gianluca
ITA has REST apis and ETL which can be used to export data from and import data into ITA.
If the customer is not comfortable using an ETL export database on the ITA server because they are not comfortable with PostgreSQL, ETL Export databases do not have to reside on the ITA server. The platform has the ability to export data to MS SQL server and Mysql as well as a remote postgres database.
Regards
Greg Sterling
Posted: 2021-02-15 10:48 AM
What type of example are you looking for?
A SQL query from data in an export database?
Regards
Greg
Posted: 2021-02-15 10:43 PM
Hi Greg
if is it possible an example from ITA to SQL and ITA to Service Now
thanks a lot
Hello Gianluca
