ITA 9.3 web client unresponsive
  • ITA 9.3 web client unresponsive
129
72
Mike-Sutton
Lieutenant Mike-Sutton
Lieutenant
Posted: ‎2022-02-09 09:39 AM
2647
Hi I have installed ITA 9.3 i can browse to the server but when i input user name and password it just sits there is there any ports i need to open other than 443? ive tried using 9.2.2 client but i get the unable to connect check network settings yet i can ping the server no problems?
TIA
Mike
  • IT Advisor
Captain
Posted: ‎2022-02-09 01:42 PM
In response to Mike-Sutton
2616
Without seeing log files, my guess would be the ITA software did not install or complete installation.
I assume the server meets minimum installation requirements? like at least  4 cpu's, 16GB of memory, 100GB disk space? It is installed on a VM?
If you are planning to share log files I'd strongly suggest you do so via support@ecostruxureit.com as this forum does not provide privacy for log information.
Regards
Greg Sterling
Replies 6
Captain
Posted: ‎2022-02-09 10:05 AM
2641
Hello Mike, this inquiry may actually be better services through the support@ecostruxureit.com email if more information is required to debug this problem.
1. Are you using local or AD/LDAP based user accounts for login?
2. Does webmin state the ITA application is running in the status view?
Regards
Greg Sterling
Mike-Sutton
Lieutenant
Posted: ‎2022-02-09 10:30 AM
In response to gsterling
2633
Hi Greg thanks looking at webmin all I'm seeing is shown in attached
cheers
Mike
Captain
Posted: ‎2022-02-09 10:58 AM
2631
No application and database entries, just web?
So your status screen does not look like this?
Mike-Sutton
Lieutenant
Posted: ‎2022-02-09 01:04 PM
2621
Cant see pic but no just web status
Captain
2617
Regards
Greg Sterling
Mike-Sutton
Lieutenant
Posted: ‎2022-02-09 01:56 PM
Hi Greg
Thanks will check spec tomorrow and liaise further with support
Cheers
Mike
