ITA 9.1.x Colo Tenant Access Questions
  • ITA 9.1.x Colo Tenant Access Questions
129
72
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2021-07-05 06:47 AM
2328
Dear Community,
I have a few questions regarding tenant login in web client:
1. Is the floor layout is meant to show in in whole? Compare to the previous version of Colo feature where tenant get to see their own cage layout only?
* The squared location is the tenant's cage.
BR
TJ
  • Data Center Operation
  • IT Advisor
Admiral
Posted: ‎2021-07-06 02:29 AM
2
2315
Hi TJ,
That's correct in latest version(s) of ITA, tenant may access the area/equipment based on permissions but may also see the reset of the 'greyed out' floor area (with no info/details).
Kind regards,
Replies 5
Posted: ‎2021-07-06 01:22 AM . Last Modified: ‎2021-07-06 08:37 PM
2320
Upgrading from DCO 8.x to IT Advisor · How to download Data Center Expert and IT in a virtual environment · Installing ITA in a location without public Internet access ITA system requirements for on-premises installations Colo and tenant Desktop client login issue possible after updating to ITA 9.1.9.
O'Reilly First Call
Admiral
2
2316
Hi TJ,
Kind regards,
Admiral
Posted: ‎2021-07-06 02:57 AM
In response to Anonymous user
Hi Jones,
Going forward please open a new 'case' when posting a question.
If the data needs to be downloaded from the Internet (such as installation files for ITA), then you would need to use a laptop or workstation that has Internet access. Download the file(s) and then transfer to a storage driver and then make it available in your closed network environment.
Currently the installation file(s) for ITA (including the latest 9.2.0 release) available as:
offline installer (such as EcoStruxureITAdvisor9.2.0-offline.iso)
and online installer (such as EcoStruxureITAdvisor9.2.0.iso)
So, if there is no Internet access during the installation then use the offline installer.
Additional info:
a more general description of upgrading from DCO 8.x to ITA:
https://helpcenter.ecostruxureit.com/hc/en-us/articles/360009560538-Upgrading-from-DCO-8-x-to-IT-Adv...
migrating/upgrading from DCO to ITA:
https://helpcenter.ecostruxureit.com/hc/en-us/articles/360006367378-Migrating-from-DCO-to-ITA
if you are upgrading from Colo to ITA, then please see this article as well:
https://helpcenter.ecostruxureit.com/hc/en-us/articles/360036670893-Can-I-upgrade-to-ITA-on-premise-...
Kind regards,
tjlaw
Lt. Commander
Posted: ‎2021-07-11 05:18 PM
In response to Jef
2281
Hi Jef,
Thanks for the clarification. Another question is that, are we able to set "customer" properties for space/room TH sensors? The tenant wishes to view the space/room sensors under their cage. I understand tenants are able to view the TH sensors installed inside the racks.
BR,
TJ
Admiral
Posted: ‎2021-07-14 11:43 PM
In response to tjlaw
Hi TJ,
You are very welcome. That's correct, tenant can view the associated temperature/humidity sensors, but we cannot set custom properties on them. In general, custom properties can be defined/set on ITA models (and not on the external systems items such as T/H sensors).
Kind regards,
