ITA 9.1.0 ETL database connection issue (platform configuration bug?)
  • ITA 9.1.0 ETL database connection issue (platform configuration bug?)
129
72
Valentin_Kozlov
Lieutenant Valentin_Kozlov Lieutenant
Lieutenant
Posted: ‎2020-08-06 05:03 AM . Last Modified: ‎2020-08-06 05:25 AM
3062
Hi Team!
I'm experiencing issue working with ETL export database.
I successfully create internal export ETL database via web-interface and it works (I can see that in etl.log).
But I was unable to connect to database with pgAdmin tool:
I've found that port 5432 was closed and open it on firewall.
Now I have another error:
There were no entries in pg_hba.conf file related to new databese:
I add 'allow all' entry to pg_hba.conf file:
host    all             all             all            trust
and set parameter to listen all addresses in postgresql.conf file:
listen_addresses = '*'
But with no luck. I still receive error about connection rejection by pg_hba.
Can anyone advice how to configure new version to allow external connections? Is there something specific?
And why didn't ITA make all the settings when create export database?
  • DCIM Support
  • IT Advisor
  • Product Feedback
Admiral
Posted: ‎2020-08-06 06:34 AM . Last Modified: ‎2020-08-06 06:37 AM
In response to Valentin_Kozlov
3040
Hi Valentin,
I could reproduce it with pgAdmin, but adding the host IP in the allowed list permits the connection:
this worked for me without further problem!
Kind regards,
Replies 5
Captain
Posted: ‎2020-08-06 05:44 AM
3055
Hello Valentin
Did you set an allowed list in the ETL definition in the web client? If not, then remote access is not allowed.
Regards
Greg Sterling
Valentin_Kozlov
Lieutenant
Posted: ‎2020-08-06 06:00 AM
In response to gsterling
3052
Hi Greg!
Did you mean this one?
I set it to 0.0.0.0, because usually it means allow all addresses.
Admiral
3041
Hi Valentin,
Kind regards,
Valentin_Kozlov
Lieutenant
Posted: ‎2020-08-06 06:53 AM
In response to Jef
3032
Great!
It works for me either, thank you!
But nothing changes in pg_hba.conf and it is very interested...
So, now we need to add all addresses we want to connect from. Of course it is more secure,but less convenient for me 🙂
Admiral
Posted: ‎2020-08-06 07:10 AM
Hi Valentin,
Sounds great, that it worked for you as well.
I could reproduce similar experience (as you) using pgAdmin but not with DbVisualizer. So basically we may add a specific IP to the allowed list when/if needed.
Kind regards,
