I would know if the DCE VM supports up to 16000 device nodes.
  • EcoStruxure IT forum
  • I would know if the DCE VM supports up to 16000 device nodes.
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 01:40 PM . Last Modified: ‎2024-04-09 04:28 AM
561
(CID:99155987)
561
Hi Alexander,
The VM version of DCE help files can be found here:
http://www.apcmedia.com/salestools/JLER-8M7NG2/JLER-8M7NG2_R5_EN.pdf?sdirect=true
Pages 6 and 7 state the limitations and resources required:
Maximum supported configuration  Up to 4025 device nodes
Hardware Resources 1 TB disk 4 GB RAM 16 CPU 2 network adapters Thin or thick provisioning
Steve
(CID:99155989)
562
Hi Alexander,
Steve
(CID:99155989)
Is not possible even if I have a more powerful hardware?
(CID:99155993)
Posted: ‎2020-07-02 01:40 PM . Last Modified: ‎2023-10-31 11:19 PM
This is a heading
