I rved this message "Fallo de la transferencia del archivo de definici
  • EcoStruxure IT forum
  • I rved this message "Fallo de la transferencia del archivo de definici
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 01:38 AM . Last Modified: ‎2024-04-05 04:04 AM
728
Hi, I received this message from an Inrow after making the confiuration of the ECO AISLE pressure sensor, do you know why??
regards
(CID:126172089)
Hi Diego,
I'm not sure what configuration you've done but the message most easily translates to a message when devices are discovered or their firmware updated in DCE. You may want to look at k-base FA177004. If the text translated to English properly, that FAQ should help.
Steve
(CID:126172096)
We had upgrade the firmware versión, after that the snmp ip addres was lose. I have put that info again into the configuration settings
Now, it is working properly
Regards
(CID:126173551)
Posted: ‎2020-07-04 01:38 AM . Last Modified: ‎2023-10-22 02:38 AM
