I cannot connect to the IT Gateway
  • EcoStruxure IT forum
  • I cannot connect to the IT Gateway
126
65
Back to EcoStruxure IT forum
huynhngochoi
Lieutenant | EcoXpert Master huynhngochoi Lieutenant | EcoXpert Master
Posted: ‎2020-12-10 08:55 PM . Last Modified: ‎2020-12-10 10:44 PM
3114
I followed your instructions,
But I can't connect to Webmin at 192.168.0.1:10000
  • Data Center Operation
  • DCIM Support
  • IT Advisor
  • IT Expert
BjarkeFenger
Lieutenant JG BjarkeFenger Lieutenant JG
Lieutenant JG
Posted: ‎2020-12-17 11:02 AM
In response to huynhngochoi
Hi Ngoc Hoi
This line of devices device have had some problems with software where the network stack does not initialize properly.
You need to reach out to our support team who are aware of this problem and can work with you to either change the impacted unit, or work with you to reinstall the base image on the device.
Bjarke Fenger
Replies 6
BjarkeFenger
Lieutenant JG
Posted: ‎2020-12-13 11:19 PM
3060
Hi @huynhngochoi
Are you using a Schneider Gateway Appliance as the Intel NUC or Dell Server?
If no, which type of server are you running the gateway on?
/Bjarke
huynhngochoi
Posted: ‎2020-12-13 11:37 PM
In response to BjarkeFenger
3055
Hi @BjarkeFenger
I do not quite understand what you mean. I just follow the instructions shown in the picture that I posted to access Webmin. But it doesn't work. Here is what I did.
I also tried to set my computer receive a DHCP address but it also failed.
NgocHoi
huynhngochoi
Posted: ‎2020-12-15 05:42 PM
Because this new product so I can not find many documents, as well as the experience of everyone.
So anyone know this error please tell me. Please help me.
Thank you very much.
NgocHoi
BjarkeFenger
Lieutenant JG
Posted: ‎2020-12-17 02:20 AM
3009
Hi huynhngochoi
I can see that you are setting a static IP on their laptop, so I suggests the DHCP isnt running properly.
Can you send us the date code from the shipping box the Gateway came in? That would help us to see which unit and version you are using.
huynhngochoi
Posted: ‎2020-12-17 05:00 AM . Last Modified: ‎2020-12-17 05:01 AM
3005
Hi @BjarkeFenger,
I sent the pictures you requested.
Ngoc Hoi
BjarkeFenger
Lieutenant JG
Hi Ngoc Hoi
Bjarke Fenger
