Posted: 2020-07-04 03:08 PM . Last Modified: 2024-04-05 02:25 AM
I can't find Dell EMC Isilon H500 and Dell EMC Isilon A2000 in "Genome Libray"
(CID:129405889)
Hi Casten Hjuler Madsen,
I just added the Dell EMC Isilon H500 to the genome library. You can start using this genome after our next genome file release, which will be done on last week of every month.
For the Dell EMC Isilon A2000, I am not able to find the exact technical specifications as of now. So I shall need some more time on this genome to process.
I will let you know once A2000 is done.
Thank you for your patience.
Regards
Thejaswi
(CID:129405918)
Posted: 2020-07-04 03:08 PM . Last Modified: 2024-04-05 02:24 AM
Hi
Here is A2000 technical specifications. 😀
https://www.emc.com/collateral/data-sheet/h16072-ss-isilon-archives.pdf
BR
Carsten
(CID:129406637)
Posted: 2020-07-04 03:09 PM . Last Modified: 2024-04-05 02:24 AM
Thank you for the user manual of A2000. I have added this genome and processed it. THis A2000 will be available to use along with the H500 genome at the end of the month after our new release.
Thejaswi
(CID:129407412)
Posted: 2020-07-04 03:09 PM . Last Modified: 2023-10-22 02:37 AM
