Modem SMS gateway
Select a Country
  • Modem SMS gateway
Cory_McDonald Champion
159
Jef Leader
114
gsterling Mentor
77
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:08 PM . Last Modified: ‎2024-04-05 02:25 AM
1349
Modem SMS gateway
Netbotz 570 which version compatible with modem ZTE MTF 100 to configure SMS Gateway
(CID:129405860)
  • NetBotz
DCIM_Support Mentor
Mentor
Hi Gono,
The supported modems and in most cases the version of firmware that supports those modems is located in k-base FA158359. This document is normally kept up to date but in the event it is not, you can always check the release notes for the newest supported modems:
PDF Library
The k-base specifically states:
With the release of Botzware 4.2, some new modem support has been added. These new modems are:
1. Zoom Model 4595 Modem (USB Stick form factor)
2. ZTE Model MF100 Modem (USB Stick form factor)
Steve
(CID:129406001)
DCIM_Support Mentor
Mentor
Hi Gono,
PDF Library
Steve
(CID:129406001)
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-04 03:08 PM . Last Modified: ‎2023-10-22 03:04 AM
