I can't connect from StruxtureWare Portal to PME
  • I can't connect from StruxtureWare Portal to PME
127
65
Posted: ‎2020-07-03 08:22 AM . Last Modified: ‎2024-04-08 03:53 AM
1364
From Portal Liferay I set "Connect to StruxtureWare System" my URL's PME with user and psw but when I try to add a portlet PME the proble occurs "Failed to get list of locations. Location lists may not be accurate"
I tried to set url ad ip adress but the probled remains
(CID:110005943)
  • Portal
  • power monitoring expert
1364
Hi Raffaele,
I think the instructions on how to configure Portal to work with "PME xx DC Edition" should be located in
Documentation > DataCenter > "PowerMonitoringExpert_DC_Ed_Installation_Commissioning_Guide" on the PME x.x DC Edition ISO.
Please notice that this might only work for PME x.x DC Edition, not "regular" PME. The portlets are very specific to data centers.
Kind regards
(CID:110006146)
Replies 4
Hi Raffaele Milan, thanks for posting. Lets see who can be of assistance here. @community any ideas? Kind regards Ditte
(CID:110006093)
1365
Hi Raffaele,
Kind regards
(CID:110006146)
Posted: ‎2020-07-03 08:23 AM . Last Modified: ‎2024-04-08 03:53 AM
I am having the same exact issue. I have verified my customer is using PME 8.2 DC Edition. I need help to understand what must be done on the portal side in order to integrate with PME. I have entered the correct information such as host name, IP address, and credentials. However, there is no documentation on the help.se-dmaas.com site that goes into any detail on if I need to use a specific URL to access the web services or not. Is there anyone who can provide assistance with this.
(CID:129411843)
Posted: ‎2020-07-03 08:23 AM . Last Modified: ‎2023-10-22 02:37 AM
