How to to trigger SMS alerts on Netbotz 450 ?
  • How to to trigger SMS alerts on Netbotz 450 ?
129
72
Posted: ‎2020-07-02 04:58 PM . Last Modified: ‎2024-04-09 02:37 AM
1337
I have successfully managed to get a multitech modem to pair with the Netbotz 450 after downgrading from 4.5 to 4.3. thanks to the forum for this nugget !!
My outstanding issue is that i cannot see how to get threshold triggers to send out an SMS. The application log just reports that email failed.
Below is a snip
Oct 29 16:50:47 CREMS-KEB-RACK2 daemon.notice nbArgusDaemon: numModules [0] numDisconnectedModules [0] daemonSpawnTime [4514] logArgusModuleListEncs 7893
Oct 29 16:50:59 CREMS-KEB-RACK2 daemon.notice nbPolicyMgr: Value Too Low : Temperature  (1) - Sensor Pod=21.9 °C
Oct 29 16:50:59 CREMS-KEB-RACK2 daemon.notice nbPolicyMgr: Clear error condition: id=nbErrorCond_7E930447
Oct 29 16:50:59 CREMS-KEB-RACK2 daemon.notice nbSendEmailAlert: Send E-mail Alert started
Oct 29 16:50:59 CREMS-KEB-RACK2 daemon.err nbSendEmailAlert: No targets to send to
TEST SMS generated
Oct 29 17:03:25 CREMS-KEB-RACK2 daemon.notice nbSendSMSAlert: Send SMS Alert started
Oct 29 17:03:25 CREMS-KEB-RACK2 daemon.notice nbSendSMSAlert: Send SMS Alert using en_GB
Oct 29 17:03:26 CREMS-KEB-RACK2 daemon.err nbSendSMSAlert: SMS make pdu max 160 30
Oct 29 17:03:33 CREMS-KEB-RACK2 daemon.notice nbSendSMSAlert: SMS Send to '0750696????' successful
Oct 29 17:03:33 CREMS-KEB-RACK2 daemon.notice nbSendSMSAlert: Send SMS Alert succeeded
Any ideas where I am going wrong.and thanks for your time ???
(CID:103586330)
  • NetBotz
Hi Steve,
Please below, you also need to set the macros to your preferences and add SIM numbers to recieve the alerts.
When setting up this alert action please use the wireless short message and not the short message email.
Felix
(CID:103586440)
Replies 4
Hi Steve,
When you created the alert action, what option did you choose? Adding a wireless modem should provide a new alert action option. How did you configure this exactly? What model modem are you using?  "No targets to send to" would seem to indicate that it's trying to send but does not have a recipient.
Steve
(CID:103586345)
Hi Steve,
Felix
(CID:103586440)
Thanks Guys Not sure I am getting the hang of the forum on accepting your answers as correct but thanks. I had default profile selected hence alerts being punted to non-existent email. On to my next post now as the modem has suddenly stopped sending sms
(CID:103586466)
Posted: ‎2020-07-02 04:58 PM . Last Modified: ‎2023-10-31 11:07 PM
